Premium Player September 2010
When only the best will do, there’s a great choice of hardware out there to cater for your needs, providing premium performance for a premium price tag. However, even with a high budget, we’re not out to waste money - building a top-end system isn’t as simple as just buying the most expensive components out there and slinging them all together. If you’ve just bought that 24in or 30in monitor, surround sound speaker kit and nice comfy leather chair with footrest (or sub as it's also known) and are looking for some kick-ass performance that won't wait for anyone, this is what we consider the very best hardware at the moment.
 Premium Player
 ProductUK Price (inc VAT)US Price (ex tax)
CPU2.8GHz Intel Core i7-930£215$290
MotherboardAsus P6X58D-E£150$220
Memory6GB 1,600MHz DDR3£110$135
Graphics Card2GB ATI Radeon HD 5970£470$650
PSUXFX Black Edition P1-750B-NLG9£100$130
CPU CoolerThermaltake Frio£35$60
Case (UK)SilverStone FT02R-W£190N/A
Case (US)SilverStone FT02B-W(£180)$240
Optical driveSATA DVD-RW£15$20
Storage (HDD)1TB Samsung SpinPoint F3£45$75
Storage (SSD)Crucial RealSSD C300 128GB£225$275
MiscHighPoint Rocket 620£40$35
Sound CardAsus Xonar DX£55$80
 Overall Price:£1,650$2,210
New This Month
The biggest change to our wish-list PC this month is the arrestingly beautiful SilverStone FT02R-W which, as a bonus, is also ace at cooling even a monster PC. This is due to a combination of the excellent Air Penetrator fans the case uses and its quirky rotated motherboard tray, a feature which is sure to make your killer PC a talking point. The bad news for US readers is that the special edition, red R-W version we reviewed isn’t available in North America yet, so they’re stuck with the equally impressive but less visually distinctive black B-W version for the time being.
We’ve also reviewed the latest versions of both the Gigabyte X58A-UD3R and the Asus P6X58D-E. Both boards are excellent and would form the basis of a reliable, quick PC, they’re also identically priced so it really is just a matter of personal choice which you go for. We’ve opted for the Asus board as its lack if IDE port isn’t a problem for a fresh build and we think it looks better.
Worth an honorable mention is the colossal EVGA SR-2 which, if money is no object, should be on the top of your shopping list. It's very expensive though, and the speed of two overclocked Xeons is only useful for massively multi-threaded applications rather than games and FaceBook. Despite this being our Premium Player build, we still have half an eye on value for money, so it’s not made it onto our shortlist.
We’ve seen a lot of storage options this month but neither the OCZ RevoDrive or the 120GB OCZ Vertex 2E were quick enough to oust the excellent 128GB Crucial C300.
And The Rest
The choice of which CPU to opt for is always tricky, especially as AMD a range of six-core Phenom II X6 CPUs, while Intel has its quad-core (eight-thread) Core i7 series and its ludicrous six-core (12-thread) Core i7-980X Extreme Edition. The reviews show that the AMD Phenom X6 II 1090T Black Edition just doesn't cut it against the Core i7-930 (let alone the i7-980X) unless you’re doing some highly multi-threaded work in specific applications. For bags of speed in pretty much every department and use, the Core i7-930 is the better bet for around £250.
The argument as to whether you should choose a Core i7-920 or an i7-930 continues. We've listed the i7-930 because there's no telling when the cheaper and only slightly less overclockable i7-920 will disappear from the shelves.
While we’d all like to have a i7-980X in our PC, the extra two cores over the i7-930 only help in certain applications – again, heavily multi-threaded semi-pro types of use. So, while the CPU is certainly desirable, it’s not actually all that useful for many of us, making the £800-odd asking price too large to swallow.
When it comes to LGA1366, we’d always prefer 6GB of memory over 3GB if possible, so we’ve gone for 6GB of 1,600MHz DDR3 RAM. The relatively high frequency will give us a bit more headroom when it comes to overclocking. For example, if we wanted to aim for a 4GHz overclock we’d use a QPI of 191MHz (as 191 x 21 = 4,011). If we’d opted for 1,333MHz memory, we’d have to use the 6x memory strap with this QPI, which would give us a memory frequency of 1,146MHz, which is a touch slow. With the 1,600MHz memory, we can safely use the 8x memory strap and have our memory run at a more healthy 1,528MHz. We wouldn’t recommend overclocking 1,333MHz memory to 1,528MHz for everyday use unless you really know your DRAM.
For storage, we’ve gone for a single 1TB Samsung SpinPoint F3 hard disk and a 128GB Crucial C300 SSD. We’d install Windows, games and slow-loading applications to the SSD, and everything else to the Samsung hard disk.
We’ve also added an Asus Xonar DX sound card to avoid conflicts with the Realtek audio codec of the motherboard and enhance the sound generally. If you're really into your audio, you might want to consider replacing the Asus Xonar DX with the Asus Xonar Xense Audio Bundle. It's finally on sale and at under £200 it's worth looking considering.
Our sister mag Custom PC recently recommended the 750W XFX Black Edition P1-750B-NLG9, which its Premium Grade award (obviously for its price and performance, rather than its name). To quote the review: 'at just over £100, the 750W XFX Black Edition...is great value for money. If you're in the market for a 700-799W PSU then it should be at the top of your shopping list.'.
The CPU cooler we’ve chosen is the Thermaltake Frio which blasted through our thermal benchmarks. With both its fans installed its one of the best cooler we’ve ever seen.
To round things off, there’s a cheap SATA DVD drive. If you haven't got a copy already, you should factor in a copy of Windows 7 - if you're confident that you won't be upgrading much, then an OEM copy should be fine, but serial upgraders need the pricier retail version.
null
